XTAR WP2 Intelligent Charger 14500/14650/17670/18500/18650/18700 Battery
+USB 5.0V/500mA voltage output
+375293669855
комплект: зарядка, провода питания 12/220 В (авто/сеть)
24 у.е.
Features:
XTAR WP2 II charger is apply to charging for two 14500/14650/17670/18500/18650/18700 3.7V Li-ion battery simultaneously but independently, it can charge for 10440/16340 when use 2pcs spacers. It is designed with algorithm (TC.CC.CV) charging method which can monitor the battery?s status real time and control charging safe automatically.
WP2 II designed with USB output function, use fully charged battery can supply electricity to those devices power below 5.0V/500mA.
WP2 II Charger adopts reverse-polarity protection circuit board and over/under voltage disconnecting technology, can prevent the possibility like sundries, wrong polarity and misoperation caused short circuit.
WP2 II built battery over discharging activating function, it can repair varying degrees discharged battery and then charging automatically, it is your first choice safer and reliable Li-ion battery charger.
WP2 II can apply to charging for two 14500/ 14650/ 14650/ 17670/ 18500/ 18650/ 18700 3.7V Li-ion battery, also for 10440/16340 when use 2pcs spacers.
