kelly"s 1200$
рама Hydroforming Aluminum alloy triple butted
вилка SR SUNTOUR Raidon RL Air, 100mm, air / Remote Lockout
рулевая колонка RITCHEY Comp Logic Zero integrated
шатуны SHIMANO Deore LX (08) M582 Hollowtech II (44x32x22T)
п/переключатель SHIMANO Deore LX M581
з/переключатель SHIMANO Deore XT (08) M772
манетки SHIMANO Deore LX SL-M580 Rapidfire Plus
скорости 27
кассета SHIMANO CS-HG50-9 (11-34T)
цепь SHIMANO CN-HG73
тормоза HAYES Stroker Ryde Hydraulic Disc
ручка тормоза HAYES Stroker Ryde
втулки SHIMANO Deore M525 Disc
спицы stainless steel
обода MAVIC XM317 Disc
покрышки MAXXIS 1.95 Ignitor
вынос KBIX PRO-Race
руль KBIX PRO-Comp
грипсы KELLYS LockRim gel
подседельный штырь RITCHEY Comp V2
седло PROLOGO Choice ProRail gel
педали WELLGO M919 (clipless)
аксессуары CAT EYE reflector set
accessories 12, 55 (19.5")
scott scale 50 1150$
Frame
Scott Scale Alloy 7005 DB
hydrafrom monocoque tubes
V dropout design
Delta SST bridge / Integ. HT
BOX chainstay bridge
Fork
Rock Shox Tora 302 / alloy steer
Coil Spring / Keyturn Lockout
reb. Adj. / 100 mm travel
Headset
Ritchey OE 1 1/8""
semi integrated 44/50mm
Derailleur (Rear)
Shimano XT RD-M772 SGS
Shadow Type / 27 Speed
Derailleur (Front)
Shimano Deore FC-M530 / 34.9mm
Shifters
Shimano Deore SL-M530
Rapidfire plus / 2 way release
w/gear indicator
Brake Levers
Avid Juicy 3.5
Brakes
Avid Juicy 3.5
185/F and 160/R mm Rotor
Crankset
Shimano FC-M542
Integrated BB
44Ax32x22 T
BB-Set
Shimano Cartridge / 68mm shell
Handlebar
Scott X-Rod
600 mm / 5° bend
H'stem
Scott Comp
4 bolt
1-1/8"" / 6° angle
Pedals
Shimano PD-M505
Clipless pedal
Seatpost
Scott Comp / 31.6mm
Seat
Scott Racing
Hub (Front)
Scott Comp Disc
Hub (Rear)
Shimano FH-M475 Disc
Chain
Shimano CN-HG53
Cassette
Shimano CS-HG50-9
11-32 T
Spokes
DT Swiss Champion Black 1.8mm
Rims
Alex TD-24 Disc 32H
Black
Tires
Scott Ozon
26 x 2.0 / 60TPI Kevlar Bead
single compound 70a
в данном случае келлис выглядит лутше в :
вилке
переклюках
ободах
втулках
цепочка
манетках
Зы про вилку ничего не знаю ... судя по описанию воздух ... но может это токо прелоад воздушный, от которого толку мало ....
вилке
переклюках
ободах
втулках
цепочка
манеткахЗы про вилку ничего не знаю ... судя по описанию воздух ... но может это токо прелоад воздушный, от которого толку мало ....
вот и я о том же... а разница в цене 50 (скалики подорожали - утром позвонил продавец и сказал что уже 1150 а было 1000 +15% это много)
я вот незнаю почему но у меня к келисам душе нележит, так же как и к рок машин
чем-то рама не устраивает? а все остальное - конструктор, а при равной цене келлис вроде как лучше по обвесу...
нет я не про то что там рама плохая, просто душа к этой марке не лежит
короче - у тебя вел другой марки ))
если те нужна обвеска - Келлис, если рама - Скейл, а вообще я бы еще порылся бы на твоем месте.
ИМХО http://velo.by/catalog/trek/mountain/trek8000.html если потянешь, если нет то: как более дешевый вариант: http://velo.by/catalog/trek/mountain/trek_6500d.html
блин сори за большую фотку
DraG отпили фото!
Сам субъективно за скейл, уж очень красивая машинка. :|)
Только вот жаль, что цена всё растёт :'( (на сайте Медведя ещё даже не исправили)
