Рюкзак от легендарного американского производителя туристического снаряжения Osprey VOLT 60, новый
Стоимость: 240 не наших
+375 29 255 66 95
Specifications
Use: backpacking and hiking.
Volume: 60 liters (3661 cu in).
Weight: 3.92 lb (1780 g).
Torso fit: 17 – 23 in (43 – 58 cm).
Waist fit: 29 – 51 in.
Dimensions: 33 x 14 x 12 in.
Frame: internal, 3.5 mm peripheral wire.
1 mm HDPE back panel.
Material: 210 D nylon double diamond ripstop, 600 D packcloth.
Maximum weight: 50 lb (23 kg).
Adjustable harness.
Adjustable waist belt.
Top access.
Floating lid.
Warranty: limited lifetime.
Sleeping bag compartment with removable divider.
AirScape back panel.
Stow-on-the-Go trekking pole attachment.
Adjustable sternum strap with emergency whistle.
Fit-on-the-Fly hip belt system.
Dual side compression straps.
Removable sleeping pad straps.
Dual attachment loops.
Dual daisy chains on the front.
Zippered hip belt pockets.
Lid zippered pocket.
Zippered mesh pocket underneath the lid.
Front stretch mesh pocket.
Dual-access stretch-mesh side pockets.
Hydration compatible.
